will it handle it?
Old May 13, 2009 | 12:23 PM
thp777's Avatar
will it handle it?
would a 92 camaro rs v6 rear end be able to handle a 454?
Old May 13, 2009 | 12:29 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: will it handle it?
nope. Better plan on a 12-bolt or 9" or S-60.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
By the way, you'll get more for your stock rear end if you sell it before you break it.
Old May 13, 2009 | 12:38 PM
thp777's Avatar
what rearend would u recommend?
Old May 13, 2009 | 12:44 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I prefer the 9", a good source is Currie. Plus if you do go 9", Strange makes an aluminum center section for it that takes GM 12-bolt gears. But if you're going to end up with a 572 in place of that 454, a few years from now, better to start with the S-60 from Strange.
Old May 13, 2009 | 12:49 PM
thp777's Avatar
would any dana 60 handle the 454 tho?
Old May 13, 2009 | 12:53 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Other dana 60s don't have the cast-in provision for the torque arm. If you want to do this with salvage-yard parts, definitely go with the Ford 9". Currie sells a torque arm bracket that you can weld to any 9"
Old May 13, 2009 | 01:05 PM
thp777's Avatar
so this would work
http://houston.craigslist.org/pts/1168106177.html
Old May 13, 2009 | 01:13 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Sure, but you may end up having to narrow it. The price isn't bad, if it includes the center section, and axles. Truck rearends are more likely to have the more agressive gear ratios, and the 31-spline axles, hopefully in a Traction-Lok.
Old May 13, 2009 | 01:18 PM
thp777's Avatar
how difficult would it be to narrow it?
the housing seems simple but the shafts idk
Old May 13, 2009 | 09:11 PM
big gear head's Avatar
I prefer the Mosr 12 bolt over the 9 inch for several reasons. First, it is lighter, second, it uses less power to turn it, and third, it is cheaper than building a 9 inch with new parts. If you want to build a 9 inch with junk yard parts then you might save some money, but it won't be as strong as the 12 bolt. There are no stock Ford differentials that are as strong as the 12 bolt Eaton Posi.
Old May 14, 2009 | 11:33 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
last year Car Craft magazine chassis-dyno-tested the old myth about which axle takes more power to run. twelve bolt versus nine inch versus dana 60. They were all within 5 horses at the rear tires.
1992Z28!
Nov 19, 2015 07:33 AM
Numbah-1
Oct 2, 2015 08:27 AM
ndndndnd
Sep 28, 2015 08:00 AM
roysatikas
Sep 22, 2015 08:15 PM
apie2546
Sep 20, 2015 01:03 PM
