issues w/700R4
Old May 20, 2009 | 12:23 AM
LoRydeRanger's Avatar
issues w/700R4
I have an 85 z28-carb motor-700R4-when i drive it(full throttle or easy driving) i have to let off and then get back on it for it to shift-otherwise it will over rev...it supposedly has a B&M Stage 2 shift kit in it too-havent looked for myself-factory torque converter too-any ideas?
Old May 20, 2009 | 08:43 AM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
Re: issues w/700R4
make sure the tv cable is set correctly or you may need to change the govenor springs
also did you make sure your tach is reading correctly?
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
