no third and fourth on my t5
Old May 21, 2009 | 08:45 AM
irocboy8292's Avatar
Car: 1986 Camaro Z-28
Engine: 3970010--5.?l
well was abusing the lt1 a little and when i power shift to third it grinded and went in to then slip and when i shift to fourth it does the same i got no third and fourth no grinding when i put it in or nothing i could put it in with out even pressing clutch.. what can this be? i was told it could be the 3rd-4th fork but would like to be sure before dropping the trans to open it up..
thanks
Old May 22, 2009 | 12:18 PM
Re: no third and fourth on my t5
bump
Old May 22, 2009 | 12:20 PM
Kevinaz's Avatar
Car: 84 Z28
Engine: 345/350
Axle/Gears: Stock
Hey, I have the same problem in my T-5, No third or Fourth, feels like nothing is their. I received a suggestion on this site to check the shifter, pulled it, put it in thrid and found it, put it in fourth, found it, now I cant get it into any other gear and neutural is a forward gear. i didnt get any other responses on this site. Think I am going to take it out and crak it open and see if its a bent rail or fork. Hopefully some of the Guru's on this site will give a hint or to as to what the problem might be.
Old May 23, 2009 | 09:56 PM
o damm thanks alot bro my mechanic teacher told me for sure it is the fork which grabs the sycros for 3-4 gear but was just seeing if i got the same advice from here i dropped mines today pretty hard to take of the top cover so i rather let a mechanic do it before i make it worth
Old Jun 28, 2009 | 06:31 PM
Kevinaz's Avatar
Car: 84 Z28
Engine: 345/350
Axle/Gears: Stock
Just an FYI, tore mine apart and third/fourth fork was destroyed, replaced both forks while i hadit apart and now it works great!
Old Jun 29, 2009 | 08:03 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Get a shifter with stops like a Pro 5.0 and you won't break the fork anymore. You're overshifting when you slam 3rd gear, which flexes the fork. The aluminum can only take it for so long before it cracks and eventually breaks. Also, if you're powershifting 3rd get ready for it to break again, because eventually it will spit some teeth.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
dusterbd
Sep 29, 2015 08:40 AM
Linson
Sep 21, 2015 01:08 PM
InfinityShade
Aug 22, 2015 08:00 PM
Linson
Aug 21, 2015 02:12 PM
