383 stroker with 700r4
Old May 22, 2009 | 11:30 AM
1984stroker's Avatar
I have an 84 camaro with a 383 stroker in it. I have been hearing that the 700r4 will not hold the 400 horsepower of the motor. But then some say it will. The trans has a 2800 stahl converter and a shift kit and has been freshly rebuilt. Will this trans hold the power of the motor? I use the car for a cruiser and i beat on it once in awhile it is not a strip car. Can anyone give me help.
Old May 22, 2009 | 01:40 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 383 stroker with 700r4
Depends on a bunch of things, but if you plan on it failing and it doesn't, great. If you plan on it failing and it does, well, you planned on that. Some factors include the internal condition of the trans, your rear axle ratio, how aggressive the converter hits, how well you can hook the power to the ground, and how you drive. A bigger number axle ratio is slightly easier on the trans than a smaller number axle ratio. An aggressive converter with drag radials will hurt the trans mnore than a lazy converter on street radials. And unless you have a dyno sheet proving your engine is at 400 horses, expect that it's actually making less. Even so, 400 hp at sea level is only 328 hp at 4500' elev. where I live. You lose 1% for each 250' elev. Then subtract for the water pump, power steering pump, and alternator.
Old May 25, 2009 | 01:38 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
id say it should be ok
im running a completely stock unit behind mine and its surviving
yes it slips when shiffting but i dubled the horse power goin to it, so if you have a shift kit and a fresh rebuild id think it would be ok
ive also had mine at the track and i dead hooked with no problems
Old May 28, 2009 | 12:28 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I would recommend installing Vette Servos and a TransGo shift kit. I had an otherwise stock 700R4 with that same setup that I beat the snot out of for two years and it didn't break until I had to drag the truck with a broken rear on the front axel, which sheared the snout off the internal reaction carrier. I rebuilt the trans with parts from a junkyard trans and it soldiers on behind a 450HP 383 spinning 4.88 gears.
What year is the trans and was it ever rebuilt?
Old May 31, 2009 | 06:33 PM
jtmoney01's Avatar
Have you checked out Monster Transmissions. They have a 700r4 that they say can hold 700hp. I don't know how much your budget is.
Old May 31, 2009 | 06:38 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
i bought a 700r4 rebuild kit from probuilt transmission a year ago and its worked great with my 470 horse motor
Old Jun 1, 2009 | 03:12 AM
Pro Built Automatics's Avatar
Watch out for those "claims"....... How "good" is the warranty is the real test...
Old Apr 30, 2018 | 06:32 AM
Bryan Carosi's Avatar
Ive been told the input shaft of the 700 is too small to handle the power from a 383. Is this true?
Old Apr 30, 2018 | 06:44 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
It will eventually will wear out. Need a beefed up 700r4 with additional clutches to hold power reliably
Old May 6, 2018 | 04:17 PM
I have never seen a failure of the 27 spline input shaft in any application. Remember all 2004R's (including Gran National's) are 27 spline. Starting in mid 1984 they went to the 30 spline and used it to the end.
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
