Help quick, A GREAT DEAL ON A 3:73
Old May 22, 2009 | 04:32 PM
jkrustchinsky's Avatar
Car: 1982 Trans Am, 1986 Gmc sierra
Hey guys, check it out. My rear end is about to blow, it clanks and clunks, the spider has alot of slop. There is a rebuilt 3:73 POSI rear end for 200 bucks. Its from a 1981 camaro.
I have a 1987 trans am with 3:73 limited slip, what modifications are necassary for installing this earlier rear end. Thanks, Josh
Old May 22, 2009 | 04:59 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Help quick, A GREAT DEAL ON A 3:73
What's the brake situation?
JamesC
Old May 22, 2009 | 05:07 PM
drums on both
Old May 22, 2009 | 05:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
brakes dont matter, its a totally different rear, the gears are different sizes. you cant use it, move on.
Old May 22, 2009 | 05:48 PM
are you kidding me, what do the gear sizes have anything to do with the adaptation. The only thing that matters is the mounting locations and if it will adapt to my current drive shaft and spring locations.
Old May 22, 2009 | 06:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the 81 camaro rear is setup for leaf springs, you car has coil springs. Not the biggest deal, but the major issue is the torque arm. There is practacially no way to install a torque arm mount on the 81 axle.
You would have to swap all the brackets, control arm mounts, spring perches, panhard mount to the other axle as well.
Im sure the width of the 2 rears are different as well.
The only way you could use it would be to install ladderbars or sometihng like that, and thats requires a lot of fabrication and $$$, which is not worth the time or $$$ on that particualr rear.
Old May 22, 2009 | 06:49 PM
damn, thanks for the help. I definitly dont need that thing then. Joshua
Old May 22, 2009 | 07:02 PM
JamesC's Avatar
Damn beer! I missed the 81 business.
JamesC
Infested
May 22, 2018 11:56 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
NinjaNife
Aug 23, 2015 11:49 AM
