want to stop[ the 1st to 4th shift how is this done
Old Sep 6, 2001 | 12:38 AM
speedfreaker's Avatar
i hate when i step on the gas only to realize my trans now is droping geaars instead of going ive heard the th350 has a 1st to 4th swith when your just cruzen and i want to stop this ive seen some stuff on it and was wondering how much it costs how hard it is to install and if it actually really works ???? thankx 4 the help
CHRIS
1983 firebird transam
Old Sep 6, 2001 | 02:05 AM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
speedfreak a TH350 has no 4th What are your trannys' symptoms?
383 86 Camaro Z28 ---1/4 mile et>13.65@103mph,,
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,3500 stall converter,shift kit,4.10 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.ALSO SECOND GEN Z28---mods:454 BBC,.546 max lift(doug herbert cam ) 750 Holley vac sec. ,Edelbrock Performer manifold,Holley electric fuel pump,Hooker headers,Flowmaster mufflers,beefed up 700r4 tranny, 3.90 gears, powertrax unit, B&M console shifter.
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Uhm... the TH350 only has three gears, not four. Also, the only trans I know of that has a 1st to 4th shift is the T56 manual trans. Its called CAGS and you remove it by getting a CAGS eliminator from various sources. This only affects 94+ fourth gens.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
IROCtometal
Sep 20, 2015 11:08 PM
TheTraut88
Sep 11, 2015 05:16 AM
IROCtometal
Sep 9, 2015 10:01 AM
TheTraut88
Sep 7, 2015 05:22 PM
dhonda200
Aug 11, 2015 11:50 PM
