AM I getting ripped off?
Old Sep 5, 2001 | 03:14 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Took my car (grand marquis) to a trans guy today, noticed the vacuum tube from the throtle body was off, so I replaced the grommet and now the car still won't shift into rd or 4th and just revs after shifting out of 2nd. He said that that vacuum hose controls the fluid the cools the gears and that the hose being off caused it to overheat and loose the gears. He also said he can see metal in the fluid, I can't so he said well its really small. So I am wondering if I'm getting the run around, any advice?
1 5/8 Hooker Competetion Headers, custom y-pipe,no cat, modified Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat, BF G-Force w-rated tires
Old Sep 6, 2001 | 04:02 AM
transfixleo's Avatar
Can I assume that you have an AOD and you lost 3rd and 4th? This is the weakest point in that tranny. Looking at it wrong in the AM will take them out. Whether it was the higher heat, I don't know. Are you being ripped off? Only if the tranny doesn't last. 2X a low price is ussually more than 1X a quality job.
Veaceonee
Sep 29, 2016 08:15 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
cstrobel65
Sep 16, 2015 11:54 AM
gta892000
Sep 16, 2015 12:37 AM
