Torque Convertors
Old Sep 3, 2001 | 01:45 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Torque Convertors
Oh, I have a feeling I will get the ole "look through the Archives" reply on this one. But since this will be my first time in this board. I am hoping for a simple answer.
Here it goes: I have an 87 Formula, that has a lot of minor mods, including a NoYoYo SysKoKal Kit from Gil Younger, on a Brand new Trans. It would pull so darned hard when the engine was cold I literally had to pop it into neutral to get the car to stop. So I put Baer Brakes on my bird it still pulls pretty good, but now I can stop.
What I want to know is about Torque convertors, will that help my situation. I was thinking about a 2200 or so.
here are some of my more major mods:
Engine & Trans & Drivetrain
.040 over 305, (312) Converted to TPI, Ported & polished intake, Plenum & runners, 9.5:1 Compression, SLP Cam, SLP headers, Cat Back Exhaust, Gil Younger NoYoYo SysKoKal Trans Kit, 1LE Aluminum driveshaft, Richmond 3.73:1 Gears.
any help is always appreciated
John
87 Formula Yellow/Black
5.1 TPI Automatic
Baer 12" brakes 4 wheels, KYB AGX Adjustable Shocks & struts, Custom Leather interior, WAAAY TOO MANY MODS TO LIST
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old Sep 3, 2001 | 02:06 PM
transfixleo's Avatar
GM #24202310. This is a 2025 stall converter that is top quality.
Old Sep 3, 2001 | 04:42 PM
86_Dan_Z28's Avatar
Car: 86 Z28
What is a Gil Younger NoYoYo SysKoKal Trans Kit?
Old Sep 3, 2001 | 06:32 PM
That would be the TransGo Shift Kit for a 700.
Old Sep 4, 2001 | 07:37 AM
okfoz's Avatar
IMO I love that shift kit, I have driven a 91 Formula and a 92 T/A Convertible with TPI, and they do NOT have the positive feeling I get from this transmission. They seemed a little slushy.
I would recommend the TransGo kit. (Gil Younger)
Is there any other suggestions for which torque convertor I should get...
I am considering going to a 383 eventually, should this make a difference which torque conv I would go with?
John
Old Sep 4, 2001 | 02:11 PM
The 383 should make strong torque down low so you probably don't want to go any higher in stall than the one I pointed out.
By the way, I have a '63 Riv. Do you know of any good sites for cars like that?
Old Sep 4, 2001 | 04:46 PM
okfoz's Avatar
start here: http://www.angelfire.com/il/76riv/links.html
and http://www.redeemer.on.ca/~cknowles/
i have some others, I will have to dig up
ther is no forums like this though that i have found. Haven't really looked either.
John
Old Sep 6, 2001 | 10:55 AM
okfoz's Avatar
What stall torque convertor came in my bird anyway??
John
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
