10 bolt posi is clanking-chattering
Old Sep 6, 2001 | 08:05 PM
blue91rs's Avatar
The axle groans and has a strong binding sound that comes from what seems more like the left wheel than the center of the axle. on straight starts and stops it does it. Its more noticeable on low speed turns , 0-20 mph.
I took the drums off thinking it was a frozen brake shoe, because thats what it feels like, but they were fine.
I've tried everything, synthetic oil w/ posi lube, regular oil w/lube, even the gm stuff. It all works for like a day, and then it starts again.
Friend thinks its the clutches in the posi, I don't think it is because it does it when it going straight also, its also only in the left wheel. I think its the outer bearing, but he says it couldn't be because it would only happen at high speeds.
If it is the outer bearing, how would i get the axle out to replace it?
if it the posi, how much am I looking at to replace it?
Thanxs guys!!
Old Sep 6, 2001 | 08:43 PM
Z28DJP1987's Avatar
I had the same problems as you describe with
my 10 bolt. Solution, find a used rear and replace it. How is the time to upgrade to
rear disc brakes (89) and later. Replaced mine with 89 B-W 9bolt 2:77 Possi & PBR disc's. Good Luck
1987 Black Camaro IROC-Z (original owner) Replaced LB9 @ 86100 miles.
New 350 Crate engine
Balanced & blueprinted
World Prod SR 67cc Heads 9.6:1 C.R.
Cam: 454lift,216dur@50,110ls
TPI Induction(from 305)
22# Fuel Injectors,AFPR&Gage
SLP Intake runners
New GM 1988 chip
K&N filters & Air Foil
Hothkis STB
SLP 1 3/4 Headers
CATCO 3" Catalytic conv.
SLP 3" Cat Back Exhaust
700R4 Auto
SLP Torque Converter (2400 stall)
B-W 9 bolt rear 2:77 Possi. Four wheel disc brakes,245/45/ZR-17 Tires
17x8.5 ATI 5 Razze Wheels
Dyno results: 211 RWHP & 282 RWTQ.
264 HP & 352#/ft at flywheel with all emission controls installed. New Toy!
Old Sep 6, 2001 | 09:17 PM
blue91rs's Avatar
well I don't have the money to do the brake swap, unless I found the rear end all together in a junkyard, and fool the joe behing the counter. Whats the likely hood that I'd find a 9 bolt with drums in a junkyard?
heres another question, when switching to disc in the rear, what will I need to adapt it to my drum lines, anything?
Old Sep 6, 2001 | 09:18 PM
blue91rs's Avatar
forgot to say thanks for the reply!
Old Sep 7, 2001 | 09:31 AM
Z28DJP1987's Avatar
If you find a 89 9bolt with disc's? You will need the emgr. brake cables, the proportioning valve and possibly some brake line fittings( SAE to Metric). Thats it, a direct bolt on.
Old Sep 7, 2001 | 10:04 AM
blue91rs's Avatar
How much should I be expecting to pay for a 9 bolt rear end? or any rear end for that matter?
Old Sep 7, 2001 | 01:03 PM
blue91rs's Avatar
ok, that any rear end thing was supposed to be a joke, Is there anything wrong with running my existing 10 bolt right into the ground? I assume when it goes I'll lose my limited slip? Any danger just using it till it dies? Is that going to effect any other parts of my drivetrain or engine? (I'm too poor right now to go junkyarding!)
Old Sep 7, 2001 | 02:31 PM
Z28DJP1987's Avatar
Blue91
Expect to pay from $200/500 depending on condition. You can drive your car to complete failure, just don't drive it to hard
(burn outs & etc). Don't worry about your Limited Slip, because that and a wheel bearing are whats shot. Start saving your money, and remenber don't abuse that rear end.
Old Sep 7, 2001 | 04:31 PM
blue91rs's Avatar
Yeah, I never really abuse this thing, its worth too much to me. The guy I bought it off of however, used it in his "stunt driving course!" I found out about this after running into one of his students who recognized the car. Turns out he used it for two years of instruction, eg. peel outs, 180s, slides, j-turns, doughnuts, figure 8s, etc. The worst part is he never changed the fluids. Oh well, I guess I learned on that one. Thanks for your reply!!
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
djmarch
Sep 13, 2015 01:35 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
