1989 IrocZ gear swap
Old May 31, 2009 | 06:00 PM
NewIrocOwner's Avatar
Car: 1989 Chevy Camaro IrocZ
Engine: 355 long block
Transmission: 700R4 Auto
Axle/Gears: 3:73 Non Posi
I have a 1989 irocZ and it had the stock gears in the rear end i just bought a new axle with 373 gears in it and i had someone just swap the 373 gears into my stock axle. Now my speedometer is off it is reading 10mph higher than i am going Does anyone have any info that can help me on this????
Old May 31, 2009 | 09:00 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: !989 IrocZ gear swap
Welcome to TGO. You need to swap the drive and/or driven gears in the trans. Providing info about your car would be helpful. If you have a T-5, check the sticky.
JamesC
Old Jun 1, 2009 | 06:26 AM
Re: 1989 IrocZ gear swap
Im sorry i really dont know much about cars how do i find out what tranny is in my car??? and what other info would you need to help me further??
Old Jun 1, 2009 | 06:42 AM
JamesC's Avatar
If you have a manual, you have a T-5, if auto, a 700R4. The drive and driven gears between the two aren't interchangeable.
JamesC
Old Jun 1, 2009 | 10:06 AM
My car is a automatic so now what do i have to do???
Old Jun 1, 2009 | 10:23 AM
JamesC's Avatar
Your OE set-up probably had 2.73's. You could ask the person who removed the gear set to verify. If the above is true, you'll need to swap both the drive and driven gears in the trans to the appropriate ones. A call to the following company will probably get you what you need:
http://www.transmissioncenter.net/sp...n_______va.htm
JamesC
camaro11j
Sep 19, 2018 08:49 AM
InfinityShade
Aug 22, 2015 08:00 PM
IBrockZ
Aug 20, 2015 12:20 PM
kyleb24
Aug 15, 2015 08:24 AM
mizz0313
Aug 12, 2015 06:45 AM
