Manual trans swap question.
Old Sep 19, 2001 | 10:57 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
I'm putting a 89 TPI 350 in a 57 chevy and I'm using an M21 4 speed.
I need to know if anyone has done this and if so, what flywheel/disc/pressure plate combo did you use??
Part numbers would be a plus, but I can get parts by application if needed.
Thanks in advance.
EB
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Sep 22, 2001 | 08:20 AM
Nordbert's Avatar
I would use an '86 to ? 305 flywheel with
153 teeth. I put a starter on an '87 IROC
a while back and it had a large frame and
parallel mounting bolts which would work with
the 153t flywheel. Use a 10.4" clutch disc with splines to match your input shaft and a pressure plate to match the flywheel. The
pressure plate should have a high diaphram
and the matching throwout bearing will be
flat on its face with no margin between the
bearing and the groove for the fork. Use a
bellhousing for 153 tooth flywheel.Because
of the fork angle/ hydraulics isssues I
recommend an earlier non-third gen housing.
Because of the large variations in fork
shapes and lengths, I can't recommend any
specific one, but I think the one from an
'80's Malibu would work fine.
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
