93-driveshaft aluminium?
Old Sep 14, 2001 | 03:15 PM
BenIroc's Avatar
Is it aluminium? Can the alu-one get rust on the surface? And does it fit in my 89 iroc?
Thanks?
BeIroc
Old Sep 14, 2001 | 04:17 PM
ede's Avatar
ede
the aluminum one should have a dull silver finish not rust ,check it with a magnet. a magnet won't stick if it isn't steel. yes a 3rd and 4th gen drive shaft are the same.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Sep 15, 2001 | 09:17 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Most 93 F-bodies have steel driveshafts. I think only the 1LE's would be aluminum.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Sep 16, 2001 | 02:58 AM
83 Crossfire TA's Avatar
'93-'97 4th gens all came from the factory with steel drive shafts. You may find some that were fixed by a dealer under a factory TSB for a vibrating DS, the part installed was the aluminum 3rd gen 1le DS...
Mark
'87 Formula 350
’83 Crossfire TA
'97 WS6 TA (for sale)
Old Sep 16, 2001 | 08:08 PM
poncho9789's Avatar
all of the gta and tta came with the JU1 aluminum driveshaft.
Old Sep 16, 2001 | 11:18 PM
Kevin91Z's Avatar
Aluminum driveshaft is JG1, not JU1.
Old Sep 20, 2001 | 06:59 PM
jigga27's Avatar
I've had an aluminum drive shaft in my car forever. No rust.
Ron Strayhorne
91 350 V8 T.A./ MSD ignition box & wires;Flowmaster cat-back exhaust;K&N filter;Crane perf. coil; semi-polished engine;Random Technology cat sitting in the garage til I can afford the other one;Pro-built stage 3 tranny in the mail...cant wait!!!
Best 1/4 mile time: 13.8@ Speedworld Motorplex (used to be called Phoenix Raceway Park). I was so excited I forgot the mph.
http://members.tripod.com/strayhorne/car.htm
Old Sep 22, 2001 | 12:10 PM
BenIroc's Avatar
The new one from GM Performance Parts
costs 260$, so I´ll go with that....
They say that the alu- driveshaft goes with the MM6 trans so I hope that it will fit my 700 trans. Well it looks like everybody say
it will fit.....
BenIroc
alpine247
Sep 16, 2015 05:25 PM
ZZ42Fast
Brakes
74
Dec 10, 2003 10:23 AM
Ward
May 13, 2001 11:22 PM
Ward
May 2, 2001 07:25 PM
Ward
May 2, 2001 11:46 AM
