Rear end swap ?
Car: 82 Camaro Z28
Engine: 305 Crossfire
Axle/Gears: 3:23
Rear end swap ?
Just had a general question for my friend in regards to his 1962 Nova..... Will a complete rear end from a 1969 Chevelle fit onto his 1962 Nova ?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Rear end swap ?
You might want to try asking on a Nova web site but I'd say no. They're probably different lengths. The Nova uses leaf springs and the Chevelle uses coil springs.
Car: 82 Camaro Z28
Axle/Gears: 3:23
Re: Rear end swap ?
Hey , thanx for the quick reply ! I kinda figured that, but just wanted to make sure. On a different topic, I have a rear end form an 89 iroc, it is a 9-bolt with a posi. It has been running great, however ,I am about to install a 487 hp LT1. I don't know to much about these 9 bolts? Can a 9 bolt handle that kind of power or should I get a fourth gen rear end ?
Car: 87 IROC L98
Re: Rear end swap ?
The fourth gen diff is weaker. It has the same weakness as a third gen 10 bolt diff except it has stronger 28 spline axles. A fourth gen diff is just as strong as a 90-92 third gen diff which also has 28 spline axles. You can't put fourth gen axles in a third gen housing.
Third and fourth gen diffs and the 9 bolt have some strength but were never a real high performance differential. They will all break eventually. You roll the dice and take a chance.
I pushed a 9 bolt into the high 11's with 3.27 gears. I switched to a beefed up 10 bolt to get a better gear ratio and pushed it into the low 11's. I then installed a 9".
Car: 82 Camaro Z28
Axle/Gears: 3:23
Re: Rear end swap ?
Car: 87 IROC L98
Re: Rear end swap ?
A diff from a 90-92 third gen is your best bet. It's unlikely you'll ever find a third gen Dana 44 since it was never in a factory production car. They were available from GM as an over the counter diff and were available in the SLP Firehawk. There are no other junkyard options for a stronger diff.
Your only other choices are an aftermarket 9", 12 bolt or Dana 60 designed to bolt into a third gen.
You can use the 9 bolt but replacement parts are expensive and hard to find as the diff is from Australia.
Re: Rear end swap ?
The '62 Nova rear end is very narrow at 58 inches total. The Camaro rear ends are all wider, especially the later ones. The '78 to '87 G body rear ends are about the same width, but not very strong and the suspension is different. The '65 to '67 Nova rear ends will bolt in and are better than the '62 rear end.
Car: 86 bird
Engine: LG4
Transmission: A4
Re: Rear end swap ?
i was thinking of putting the diff from my 90 bird v6 but are the gear ratios better meaning shorter for better acceleration? And can that handle a stock 305
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
