tranny mount question read me!
Old Sep 25, 2001 | 04:34 PM
pimpintheRS's Avatar
okay when i hit hte gas hard from a stop i get a loud popping noise and i think almost sure it is the tranny mount.. tell me if i am wrong.. the real question is how hard is it to fix it? can i do it i have never dropped a tranny but i cant even punch it from a stop light anymore and it happens from 1-2 shift at wot... any help is aprreciated..
Shawn
....yeah my thirdgen.org name is gay but i've had it for a while.....
91 RS 5.0 TBI
14x3 open element.. i liked alot
160*stat... made my car run a lil cooler
msd coil and taylor wires ...not noticed
with ac delco plugs.. i like but not noticed
removed rear hood seal.. runs cooler i liked
accel cap and rotor..not a real mod
coming soon 3.42's with slp posi.. my first big mod!!!
lt1 cam shaft in the mail!! now 2 big mods to do!
Clarion cd player 2 planet audio 6x9's 2 tweeters and one MTX 10" sub in a bandpass all running off 2 separate 200w amps gotta love the f-body trunk, system hits!!!
Old Sep 25, 2001 | 04:51 PM
Jinx2148's Avatar
Ok, I think it is your tranny mount, and its easy as hell to change,(I've done a few in the past month) you get the car up(to get under) then jack up the tranny,(it will fall if you don't) so the you un bolt the transmission mount(located in the center of the crossmember) then unbolt the crossmember and finally unbolt the trans-mount from said transmission. Now, just put the new mount in, do everything in reverse. The reason I have done this soo many times recently is that my 92 3.1 manual seems to have a rather dead part.. I can't find it anywhere, I called the local dealerships and they told me GM stopped making the part..if someone knows where I can get the part tell me, also Jegs and Summit both sent me the Automatic trans-mount, which simply doesn't fit, even though they keep telling me it does, the bolts/bolt holes just don't line up..I'm frustrated cuz I can't launch or even think about getting on it in 1-2-3...good luck with yours..
Old Sep 25, 2001 | 06:31 PM
CODY BEHNKE's Avatar
All mounts should be the same auto or manual mine is a manual and the 1LE mount for an auto fit mine just right.
Old Sep 25, 2001 | 09:56 PM
before i call to find out i am wondering how much it cost for a new tranny mount and is it 2 tranny mounts?... sorry if i sound dumb..
Shawn
[This message has been edited by pimpintheRS (edited September 27, 2001).]
Old Sep 26, 2001 | 05:16 PM
Jinx2148's Avatar
Its one mount(kit) depending on which one you get it may have several pieces. Unless your getting a poly mount or "high performance" mount look to spend less than $10.
Old Sep 28, 2001 | 02:46 AM
okay now someone is telling me it could be an engine mount too.. how can i check if it is an engine mount and how much for one of them mother fu kers... damn all i want is the knock to stop...
Shawn
Old Sep 29, 2001 | 08:21 AM
Jcpstrat's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Jinx2148:
"I've done a few in the past month..</font>
With your experience ... can the transmission mount be bad without being broken?
Old Sep 29, 2001 | 12:53 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
I just changed mine last week what a big diff. no more big bang. A trans mount should be one piece mine was in three. It took 30 mins that was from the time I open the garage door till I closed it.
Old Sep 29, 2001 | 11:51 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
im 16 and the first thing i had to do to my car was change my tranny mount cuz i broke it at the drag strip
it is sooo easy to do
your makin it sound like its gonna b something hard to do
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
camaro11j
Sep 19, 2018 08:49 AM
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
