how-to change the front pump on 700r4
Old Oct 1, 2001 | 10:49 PM
83z28400sbc's Avatar
i was wondering how hard it was to change the front pump on a 700r4 and what it involved to do it any info would help thanks
83 z28 400sbc 85 v6 88 v6
Old Oct 2, 2001 | 07:27 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
First you need to pull the tranny. Then you need to pull the pan and remove teh TCC solenoild. Then you need to remove the AuxVB transer tube if its an '87 or later, then remove all the bolts and then get the puller to pull the pump.
Why do you think you need a new pump?
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Oct 3, 2001 | 12:45 AM
well u see on the fourth of july the front seal on the tranny popped out , ya i know kinda weird. so i pulled the tranny and put a new one in , and when i put the tranny back in i didnt have the converter lined up and started tightening the bell housing bolts i heard two pops. the front pump. and when i started the motor i have nothing the tranny is not pumping fluid. i was in a hurry and messed up. might i add i work on cars all by my self in a garage with no lift just put it up on four car ramps and use a jack so go figure. so it isnt that hard to change then i take it. do u know of any web sites on here that have diagrams of a 700r4. and the tranny is a 89 thanks alot.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
jklein337
Sep 19, 2018 06:23 PM
kyleb24
Aug 15, 2015 08:24 AM
TreDeClaw
Aug 14, 2015 06:58 PM
