How to check transmission fluid in 83 camaro
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Re: How to check transmission fluid in 83 camaro
With the engine running and warmed up to operating temperature, there is a dipstick near the firewall on the passenger side of the car. If you can find the oil dipstick, the trans one is right behind that. Pull that out and check the fluid level, and add as needed. It may be different on your 83, but thats where it is on my 88.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Manual or auto trans? Auto will have a dipstick, manual will not.
Only way to check with a manual trans is to remove the fill plug and feel where the level is with your finger.
Car: '83 camaro z28
ya its a manual sorry probably a big part, alright ill try to find that and any clue to what fluid i should be using
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
The manual trans is a bit of a pain to check...there are two square pipe plugs on the right (passenger) side of the trans, the lower one is to drain the oil and the upper (nearly invisible) is for filling and checking the level. Use a wrench to take the upper plug out and with your finger or hooked wire measuring tool see that the level is at or near the hole. The oil should be ATF or GM Synchromesh oil. Thicker oils will not flow through the funnel to the fifth gear sub housing and result in tranny damage.
His is an 83 like mine... If he has a T5 (5-spd) then they used gear oil in those years, not ATF.
Car: '83 camaro z28
well my dad and i went to napa and they gave us an atm and we just took it for a drive and my dad said it shifted alot nicer but made that noise when i shifted it into reverse
maroe624
Apr 16, 2017 08:29 AM
backtothe80s
Sep 5, 2015 12:39 AM
92camaroJoe
Aug 13, 2015 06:07 AM
