tranny mount
Old Oct 16, 2001 | 08:46 AM
silver89Rs's Avatar
tranny mount
i changed my trans mount about 9 months ago and the other day it started t make the same klunking noise again wha would make th trans mount go bad so fast?
89 Rs camaro
305 tbi
3in flowmaster muffler
manderal bent pipe
no cat
ELECTRONICS
viper alarm
pioneer 4-way 6x9's
15' orion sub in a bandpass box
150x1 kenwood amp
140watt aiwa head unit
Old Oct 16, 2001 | 02:19 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It goes so fast because it's made of rubber, and not meant to take any abuse. Get the polyurethane one from Energy Suspension. It costs $25 from Summit Racing, 800-230-3030, and you'll never ever have to replace it. (I went through 3 in two years before buying the ES one. It's been 4 years now, and the ES one is still solid.)
The part # is 3-1108G (for black), 3-1108B (for blue), 3-1108R (for red)... (put an ENS- in front of those #'s when you call Summit)
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Oct 16, 2001 | 10:34 PM
silver89Rs's Avatar
i already out on a prothane mount and that is the one on there now. could a bad motor mount be causing the transmount to go bad faster?
Old Oct 19, 2001 | 12:48 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I dont' know about Prothane's trans mount; most people use the ES one. It's got a safety interlock on it in case the poly breaks. But yeah a bad motor mount would probably throw more stress on the trans; ES also makes poly v8 mounts...
Old Oct 19, 2001 | 04:43 PM
ede's Avatar
ede
i don't think you could break a ES poly mount. at least i never could and i've put them in 4 thirdgens
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 19, 2001 | 09:14 PM
Jcpstrat's Avatar
Can a transmission mount go bad without actually separating? Maybe just loose its resiliency and allow more movement than it should.
Old Oct 2, 2002 | 04:21 PM
Oscar's Avatar
TomP.
did you use the spacer so-called pre-load plate between the mount and tranny? I noticed the ES mount is about 1/2" if not more taller. I feel like it may be too tall because I get extra noise or reverberation at certain RPM's. Almost like a header touching agianst the body. Alot louder inside the cockpit too. Should I remove the first plate?
Old Oct 2, 2002 | 05:03 PM
2laneblacktop's Avatar
Instead of using the poly mount, I made my own. I fabricated a new one using the measurements off the rubber one, but made it out of steel....talk about ridged. Solid motor mounts and tranny mount. You can feel everything, its pretty cool. It worked real well too.
Old Oct 2, 2002 | 10:41 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
that is a good solid mount but its also a good way to break a transmission case, unless of course your car doesn't flex AT ALL. but i'm sure it still does
Old Oct 2, 2002 | 11:21 PM
If the 60's cars can get away with it, maybe I can too. I have never heard of breaking a case. My dad has a 67 chevelle with a Muncie in it and it has a solid steel mount. No problems there.
Old Oct 3, 2002 | 06:18 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
His Chevelle also has a frame, and your car does not. It's risky. Broken cases happen all the time from that. People even break their blocks doing it.
Old Oct 3, 2002 | 04:02 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I've been running the Moroso steel motor and trans mounts for years, even on F-bodys.
Never broke or cracked a trans or a mount on any of them.
Rock solid and never replace one again.
Don't believe the hype.
My 2 cents.
-Rich-
Old Oct 3, 2002 | 04:05 PM
SteveSpohn's Avatar
The Prothane transmission mount has a safety interlock just like the ES mount. I doubt your broke that mount. The Prothane mount does not have the shim plate, and it is actually the CORRECT height, unlike the ES mount. You don't get the vibration headaches with the Prothane mount. It's what we install here at the shop.
Check your torque arm mount, could very well be your culprit.
Steve
Old Oct 3, 2002 | 05:46 PM
Oscar's Avatar
Mr. Moderator.
Thank you, thank you, thank you. A thousand thank yous.
I'll order my prothane mount tonight and return the ES one.
a million thank yous!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jan 2, 2003 | 03:44 PM
HanMan's Avatar
Can I get a part number from summit on the prothane? also, should i order these in a pair or can i just replace the one thats broken? I came up with ptp-7-1604-bl for the black mount.
Old Jan 2, 2003 | 07:40 PM
Oscar's Avatar
HanMan,
I got mine from summit. Call'em up. I'm at work so I don't have the part number here. I can get at home if you really need it but Summit can give to you or it's in the catalogue. There's only one tranny mount and it fits most of GM.
Hope that helps.
Oscar.
Old Jan 3, 2003 | 01:21 PM
HanMan's Avatar
I assume it fits most GM since it says that But id hate to order this part and not have it fit since its for a friend. Its actually his 3rd gen. My car is actually a 95 thunderbird V8. His has 180,000 miles and has just a couple problems ::sarcasm::
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
