What color driven gear do I need? Quick
Car: 89 IROC-Z
Engine: 383
I need to get a new driven gear housing this week. The car is an IROC with the 16 inch rims. It had stock 2.73 gears and I just put in 3.43's. I need to order this by wednesday.
Riccioli Performance Motorworks
--RPM Racing--
Going to fire it up for the first time next weekend as long as I get the speedo driven gear I broke!! 383 with Super Ram, Bosch 24# SVO's, MSD, Edelbrock 58 mm TB, 700R4 tranny, Eibach springs, Koni 12 way adjustable shocks and struts, and more!! Please pray that it runs when I try to start it....I've never done this before you know.
--RPM Racing--
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Assuming this is a 700R4 automatic, since you didnt mention it, a quick search of this board would tell you its 15 and 42.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Car: 89 IROC-Z
Engine: 383
Do I already have a 15 or not?? If not where does that one go?
--RPM Racing--
--RPM Racing--
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Its the drive gear on the output shaft of the transmission. Just pull out the driven gear and look inside to see what color the drive gear is.
Car: 89 IROC-Z
Engine: 383
OK now I'm confused. I searched through the old posts and I'm bewildered. I saw some posts where people said they had to remove the tranny to replace the drive gear.....I don't want to do that. Is there any way to change it without removing the tranny or tearing off the tailshaft? Also I need to get the sleeve because that's what I broke in the first place. Does anyone know if an 89 IROC with a 700R4 came with the long or short style sleeve?
--RPM Racing--
--RPM Racing--
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
To get to the drive gear you will have to remove the tail-shaft (and drive-shaft), but not the entire transmission unless the drive gear is the same color as the one you need.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Richmond 3:42 gears, Torsen HD Posi
Sights & Sounds:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers. Z28 grille w/aftermarket lights, MacEwen whiteface gauges
NEXT UP: TBI & Suspension mods
Performance:
Sights & Sounds:
Car: 89 IROC-Z
Engine: 383
Is it safe to assume that there is a tailshaft gasket that I will need to get? Is this the only gasket I will need? What about an o-ring for the driven gear housing? It was just rebuilt so there's a chance I may be able to reuse many of the seals but I just want to be prepared.
--RPM Racing--
--RPM Racing--
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
What kind of rear axle has a 3.43 gear ratio? Are you sure it is not a 3.42 gear?
Like others have said, the tailshaft housing will need to be removed to get the drive gear off the output shaft if you need to replace it. What gear ratio did the rear axle used to be? What color is the drive gear? The driven gear? What part did you break, the VSS itself (as in the part that the wiring harness plugs into)?
And for g0ds sake, settle down and take it one step at a time...... If you do have a 3.42 gear and the transmission has the grey drive gear (the one on the output shaft of the transmission), all you need to do is get the yellow driven gear. If the transmission has some other color drive gear, you will need to replace it with the grey drive gear and also get the yellow driven gear for the VSS. The GM part numbers are below for the gears you need (if it is a 3.42). you should not need any other parts to do the swap.
15T Drive (8642620) Gray
41T Driven (25513048) Yellow
If you need the VSS (if that is what you broke), just head over to the dealer and look up the VSS for an 89 IROC or whatever application you need this for.....
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
1987 GTA L98 MD8
My GTA
LT1Formula
Aug 20, 2015 09:36 PM
db057
Aug 11, 2015 10:11 PM
