What do I plug the hole in my tranny hump with?
Old Jul 16, 2009 | 04:52 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
In my transmission hump (87 IrOC Z, 700r4) their is a hole in the transmission hump where my shift cable goes. What is intended to be in that hole because I get a lot of heat and exhaust from their. I would assume that their was a gasket their previously. What should I plug this with ?
Old Jul 16, 2009 | 10:24 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: What do I plug the hole in my tranny hump with?
If you can see the below pic, you'll see a large thick rubber gasket on the cable in the top of the pic - the cable should have one of these on it, they put them on during assembly - if you're missing it, you might could carefully cut one out of a JY car, or just get a new $21 cable that has it on. It's about the size of a beer can IIRC.
http://www.autozone.com/autozone/cat...uestid=2339973
Old Jul 17, 2009 | 01:09 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
It's just a big rubber disc with cut in it for the shifter cable to go through it. I'd try to just tape it shut or put some foam over it or something.
Old Jul 17, 2009 | 01:44 AM
Car: 1987 IROC Z
Yeah.. no way im paying to replace that for kicks.. i'll make something up with that expanding foam. Thanks guys... thought it might be a simple fix..
BurlyChev
Aug 22, 2015 01:52 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
