propotioning valve
Old Oct 31, 2001 | 12:54 AM
Momar's Avatar
propotioning valve
When converting to disk brakes you are supposed to change the proportioning valve right? Is this necesarry? Doesnt it just transfer the ammount of pressure that go to the front/rear brakes. If it was not changed I would think that you would just keep the same percentage of braking from the front and rear as before. Is my thinking flawed in some way or can the proportioning valve be left in.
Ben
Old Oct 31, 2001 | 12:54 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You'd probably see better braking performance, but I've heard of guys leaving the disc/drum m/c and prop valve in, and having no problems. I swapped mine for the correct 4-wheel-disc one. You might want to ask this on the Suspension/Chassis board... or, maybe search that board for "prop valve".
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Oct 31, 2001 | 01:27 PM
SoCo80p's Avatar
if your going to 4WD you have to swap the master, booster, P-valve, and parking brake cables, if you want it to work right you have to swap ALL these things, otherwise it will stop like sh*t
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
