Launching effects...
Old Nov 8, 2001 | 09:21 PM
ChevyLuva3's Avatar
Hey all, this question is for both auto and manual owners. You all know launching techniques like "dropping the clutch"(manual) and "the neutral drop"(auto). Where for the manual you hold down clutch, while flooring the gas pedal until desired rpm (say 7000) then drop the clutch and go. And for auto, putting it in neutral, flooring the gas until desired rpm (say 7000) then drop the stick to D and go. Now my question, which "drop" has a worse affect on its transmission?
6 months and counting... the search for a Camaro goes on...
Old Nov 8, 2001 | 09:24 PM
SoCo80p's Avatar
the auto hands down, doing the "death drop" will blow a auto in no time, dumping the clutch on a manual really doesnt do anything except mabey wear your clutch out a little faster, thats why auto's use a trans brake if they want to wind out and launch
Old Nov 8, 2001 | 11:00 PM
skipsZ28's Avatar
Car: 85 Iroc
Engine: 385"
Dumping the clutch at that high of rpms is relativly bad on stock clutches. Had that problem in 94 ranger when I was 16, literally found chunks of the clutch when trans went.
Old Nov 8, 2001 | 11:34 PM
cort351w's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ChevyLuva3:
Where for the manual you hold down clutch, while flooring the gas pedal until desired rpm (say 7000) then drop the clutch and go</font>
7000?!? I haven't ever heard that one before.
Old Nov 9, 2001 | 03:31 AM
transfixleo's Avatar
It is hard on standards/clutches/drivelines to do that and it will kill an auto. At 7000 RPM you better have a scatter shield and blanket on there. Ever hear of Don Garlits?
[This message has been edited by transfixleo (edited November 10, 2001).]
Old Nov 9, 2001 | 05:03 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Transmission: TH-350
</font>
7000 r.p.m.s what in the hell do you have?lol
&lt;&lt;Ths Stang Stomper&gt;&gt;
Old Nov 9, 2001 | 09:15 PM
ChevyLuva3's Avatar
LOL, guys I was just saying 7000 rpm for argument sake, I've heard other people do it. I was just using the number 7000 as the highest rpm, to see the worst that could happen, and which tranny would get killed first. If 7000 is too high a number, how bout 4000.
Old Nov 9, 2001 | 09:30 PM
Pro Built Automatics's Avatar
Doing neutral drops is insane, there is NOTHING to be gained and everything to lose. Broken parts can be: input shaft, input drum, output shaft, sunshell, etc. Burnt forward clutches in about one or two tries if you don't break anything.
Old Nov 10, 2001 | 01:47 AM
"If 7000 is too high a number, how bout 4000"
How about a video game instead? It will save you allot of money and embaresment in the long run.
"I've heard other people do it"
Just out of curiousity, how old are you?
Old Nov 10, 2001 | 02:21 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I've heard other people do it.</font>
By 'it' you must mean feel the need to completely destroy their transmission, right?
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Nov 10, 2001 | 03:09 AM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
dont ever do a neutral drop... went through 2 trannys like that lol... just get a stall if its an auto and stall it up... let it roll out a bit. then NAIL IT.... BYE BYE SLOWSTANG!!!!!!!!!!!!
305, TPI,compucam 2030 cam, air foil, 8.8 wires, accel super coil, dynomax headers, custom y-pipe, cut out, 80 series flowmaster, just installed my 3.08 posi disc brake setup...(3.42-3.73 on the way). and a stage 4 chip :0). hittin a sad 15.1 after the chip with 2.73 open diff....
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
darwinprice
17
Oct 11, 2015 11:51 PM
tuningnewb
Sep 23, 2015 07:06 PM
Chevy3shitty
Sep 1, 2015 02:10 AM
