t-5 replacement
Old Aug 2, 2009 | 12:58 AM
aweTastic's Avatar
Car: 1989 Camaro IROC-Z28
Engine: Rebuilt 350TPI (see sig)
Transmission: is being replaced...
Axle/Gears: 20 year old G92 Borg-Warner 3.45
t-5 replacement
I just recently blew up my wc t5 it was a rebuilt for an 89 LB9 with 3.45 rear gears and cable speedo.
the motor is an L98 now but thats the only change
Im putting a t-5 back into it but havent done any investigation to make sure its the same
I plan on just removing the old tranny from the bellhousing and shifter; dropping the crossmember and sliding the new t-5 in the old ones place.
I was wondering what I need to look for to make sure the new t5 will work right and if ill be able to just slide it in like I plan or if I should anticipate any problems
thanks in advance
Last edited by aweTastic; Aug 2, 2009 at 09:09 AM. Reason: typo: its not electric speedo
Old Aug 2, 2009 | 07:03 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: t-5 replacement
Originally Posted by aweTastic
I just recently blew up my wc t5 it was a rebuilt for an 89 LB9 with 3.45 rear gears and electric speedo.
Perhaps I misunderstand, but an 89 IROC would have a cable-driven speedo. The swap is straightforward. The sticky might have something useful.
JamesC
Old Aug 2, 2009 | 09:08 AM
aweTastic's Avatar
Re: t-5 replacement
You are right it was a mistake on my part i meant to say it was a cable speedo and I checked the stickys and found out that certain t-5s had different gears and shafts but I figure if the shafts are the same the gears wont do anything but change fuel economy and speedo right?
Old Aug 2, 2009 | 10:58 AM
JamesC's Avatar
Re: t-5 replacement
I'd chose another Chevy WC T-5 (88-92) from a V8 and you'll be good to go (though, of course, an earlier non-WC would work. I'm unsure of the years there, perhaps 84 to 87). If the replacement WC was originally electronic, simply swap your current speedo sleeve into the replacement. You may need to swap the drive and/or driven gears to make the speedo read correctly. More pedestrian cars got the .63 overdrive, while the more performance-oriented cars, were equipped with .74, IIRC.
JamesC
Old Aug 2, 2009 | 11:43 AM
aweTastic's Avatar
Re: t-5 replacement
Well a buddy of mine runs a junk yard and he gave me the new t-5 and its the only one he could find so if its not wc Im gonna have to deal which is kinda depressing...
I know that the wc is pretty much the same but with different bearings correct? so if its not a wc is there anywhere I could buy the bearings and possibly anything else to beef up the strength of the tranny? The motor has almost 500ft-lbs of torque which is way over the t-5 rating...
Im sure I can do the work myself Ive just never torn apart the inside of one before any suggestions?
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
