LOST GEARS->2nd, 3d and 4th.
Old Nov 13, 2001 | 01:47 PM
84blackbeast's Avatar
Gota question about my T/A.Last week I was driving into town going about 60 and i kinda punched it a bit to kick it down into 3(700r4 trany)when i did it acted like it went into neutral.i stoped and put it in park and tryed going again.It would never shift in 2,3 or OD.Pissed me off... it doesnt look like the kick down cable and fluid levels good.I think the kick down band may have gotten stuck or something else like that. any info?
Howie McReynolds
Old Nov 13, 2001 | 02:37 PM
Pro Built Automatics's Avatar
It sounds like you broke the governor gear (common). First check to see if the TV cable is free (not stuck) and the TV adjustment is right (as per transfixleo) on this. If it is correct, then most likely the governor gear needs to be replaced.
Old Nov 17, 2001 | 12:43 AM
19WS6T/A91's Avatar
I had a similar problem with my trans. Mine would not shift into 3rd or 4th gear i had no problem with 2nd. With mine after 2nd gear it seemed like it was in neutral. The transmission guy told me that my third and fourth gear clutches were burned up. Hopefully this will help you. Good luck getting it fixed.
dhonda200
Aug 11, 2015 11:50 PM
Black88Z
Jul 21, 2013 07:10 PM
V8Astro Captain
Sep 23, 2005 02:05 AM
Marin
Sep 15, 2003 11:06 PM
