700r4 wont leave 3rd
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Car: 86 T/A T-top, LG4, auto
Engine: 305 LG4, CC Rochester 4BBL
Axle/Gears: also; 70 Vette, L46, 4 spd
Re: 700r4 wont leave 3rd
A stock 700R4 doesn't shift into overdrive at wide open throttle. I have the same issue with mine but never really noticed it untill I changed the gears from 2.73's to 3.42's... I looked into it a while back but never got around to doing it. There are a couple of different parts out there that are supposed to solve this and if I remember right you can swap them with the tranny still in the car.
You can block the 3-4 PT passages in the TV plunger sleeve, this will give you WOT shifts as long as the governor does not have a higher WOT shift point. This has been posted before by someone who has my instructions on how to do this. If you have a fax I can send them to you. You will need to remove the pan, filter, and the two screws that hold the bell crank on the valve body, remove the pin that is holding the TV plunger, pull the TV plunger sleeve, make the modification, (You install two Allen screws in the two 3-4 PT passages will solve this), and reinstall in reverse order. Cost of two Allen screws, $.034. Dana
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
what kind of fuel system is it? if its and carburetor check the geometry on the tv cable linkage especially if its a holley
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
