T-56 tranny
Old Nov 19, 2001 | 11:45 AM
82sportcoupe's Avatar
T-56 tranny
Im sure that this question has been asked by countless others but, would a T-56 tranny bolt up to a 1982 Camaro SC w/ a 350? i cant forsee any reason why it wouldnt. help me out a yes/ no answer would be sufficient
Old Nov 19, 2001 | 12:42 PM
ScreaminDeamin85Z's Avatar
yes it will bolt up just fine. if using a 2 piece rear main you need a custom flywheel though. if you are using a 1 piece rear main you can use the stock lt1 flywheel.
Brandon
"ScreaminDeamin 360"
1989 IROC 350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
T-56 ,McLeod clutch, LT4 PP
Newest Pictures
http://screamindeamin.cz28.com/newimages
http://ScreaminDeamin.cz28.com
Old Nov 19, 2001 | 06:47 PM
plain82's Avatar
If the T-56 is the same length as a T-5, you will need to move your crossmember back around 1 1/2 inches. The driveshaft is also 3 1/4 inches shorter. Good luck.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
tonys91rs
Oct 10, 2015 03:31 PM
bjpotter
Oct 4, 2015 07:48 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
