Transmission Cooling lines
Old Nov 6, 2001 | 01:03 PM
Hank Brote's Avatar
Has anyone changed their trans lines to Flex lines ? What lines did you use? Fittings ?
Any help would be appreciated.
Hank
87'IROC Z28
Hanks 87 IROC
Old Nov 7, 2001 | 12:07 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
You could just change the metal lines to hose, and attach the hose to some brass fittings that will thread into the tranny and radiator. Make sure you get hose designed for transmission coolers. This would be much easier than messing with the metal lines, as they are a major pain in the you-know-what.
91 Z28
Come see The Vicious...
Old Nov 20, 2001 | 11:13 AM
Hank Brote's Avatar
Anyone else ? I really want to route my lines in a different manner to keep them away from heat sources......... Just like to know the AN type fittings that would be needed.
Hank
87'IROC Z28
Hanks 87 IROC
Old Nov 20, 2001 | 12:45 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
What about bending & flaring new lines? Then you could re-use the fittings...?
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 21, 2001 | 12:52 AM
JunkHead84's Avatar
i used the metal lines from the radiator all the way until i got to the header, then i switched to hose so i could reroute it away from the heat source.
AussiePr0nCar
Mar 6, 2020 04:04 PM
Reddeath210
Oct 6, 2015 08:20 AM
Dialed_In
Aug 20, 2015 01:45 PM
Leggman1
Aug 6, 2015 04:15 AM
