options
Old Nov 20, 2001 | 09:31 AM
speedfreaker's Avatar
options
is their anything other then the t.v cable to adjust the 700r4 transmission for firmer or more correct shifts
CHRIS
1983 firebird transam
edelbrock performer rpm intake 360*k&n intake 160 theroostat gitting trans raced up and lots and lots of plans 4 the future
Old Nov 20, 2001 | 11:23 AM
Momar's Avatar
Not without getting into the acutal transmission. The t/v cable should not be used to change your shift points or firmness. It shouold be set so that your tranny will know when you are light throttle, full throttle or anywhere inbetween. You can modify valves and springs in the valve body to change shift points or the way it shifts to an extent. There is also a governer that can be replaced with one of different shift points or modified untill you get the right shift points by adding and removing weights. I think that I heard that B&M made a kit for adjusting the governer but I am not sure.
Old Nov 20, 2001 | 12:47 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I think it's on their website, http://www.bmracing.com !
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Nov 21, 2001 | 04:08 AM
transfixleo's Avatar
Momar answered this very well. The TV setting is only meant to relay throttle position info to the VB. If you want to get firmer shifts AND increase the life of the tranny then you will need the TransGo SHift Kit or Reprogramming Kit.
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
gixxer92
May 18, 2017 11:20 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
