TH 350 WITH 2.73 s
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
i think about 2-2500 depending on your tire size, it might be less than that.
Wide Open Till You See *** ...Then Brake
89 T/A Clone
406 in progress
TH700R4 3.42 Posi
89 T/A Clone
406 in progress
TH700R4 3.42 Posi
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Same rpm as a 700R4 when in D, not OD.
It will depend on how tall your tires are. Taller tires will give a lower rpm at the same speed as short tires.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
