transfixleo..or anyone knowledgeable on th700r4
Old Nov 23, 2001 | 05:47 AM
mark406's Avatar
ok..heres the deal guys..i have an 82 transam..original 305 with 4 speed stick shift.ive since converted to 406 cube sbc and th700r4 from an 87 formula 350.problem is...my speedo was cable driven..and my new 700r4 has electronic hookup for speedo..heres the question..lol.
i have an 89 v6 firebird,with a t5 5 speed tranny...is there a way to swap the instrument cluster from my 89..into my 82..and have the speedo work?..without alot of eletrical modifications?..if not..how can i get my speedo working? id like to use the one out ov my 89..becuase it at least goes to 120..and the 6k redline 8k max tach is better suited to my motor...any ideas?
Old Nov 23, 2001 | 06:00 AM
Pro Built Automatics's Avatar
Change the speedo gears from your existing trans and change to the earlier setup, you had in the beginning.
Old Nov 23, 2001 | 03:26 PM
mark406's Avatar
no..my new 700r4 has an electronic speedo hookup..my speedo is cable driven therefore it wont connect.what i was wondering was...since the speedo in my 89 v6 is electronic..and my 700r4 has electronic hookup..if theres a way to use the 89s guage cluster.
Old Nov 23, 2001 | 06:28 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
It would be ALOT easier if you got a the speedo gear and the little housing to go with it for lets say a 89 Camaro and that would enable you to use your stock setup. The cable setup. Otherwise you will hve to change out the entire dash wiring or cobble up your existing one to make it work.
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
LT1 intake soon...if I can find one!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire
SHE NOW RUNS!!!!
Flowmaster exhaust
LT1 Injectors
LT1 intake also if I can find one!!
Old Nov 23, 2001 | 10:10 PM
Crosley4's Avatar
<font face="Verdana, Arial" size="2">Originally posted by mark406:
no..my new 700r4 has an electronic speedo hookup..my speedo is cable driven therefore it wont connect.what i was wondering was...since the speedo in my 89 v6 is electronic..and my 700r4 has electronic hookup..if theres a way to use the 89s guage cluster.</font>
============ no.... you don't understand. The electronic speedo stuff can be removed from the newer trans and the old style of gear driven parts installed on the newer 700 trans.
2001 Ford 150 SuperCrew
2000 Silverado 1500
1985 Camaro V6
1962 Ford Falcon
1961 Dodge Lancer 350 chevy power
1961 Morris Minor 1000
1961 BugEye Sprite
2-1951 Crosley wagons
1948 Crosley wagon
1947 Crosley Sedan
1947 Crosley Pick-up
1948 Simca
Cleotiz
Jan 6, 2018 08:56 PM
camaronils
Sep 20, 2015 02:57 PM
LilJayV10
Dec 18, 2001 06:20 AM
Ward
Nov 26, 2001 08:02 AM
Ward
Nov 26, 2001 07:49 AM
