how hard is a th400 swap
Old Nov 23, 2001 | 12:13 PM
killer305's Avatar
im building a 383 stocker that should have around 450-500 hp, and in a year or so after that im goint to get a 6-71 blower witch should bring it to the 600hp range, so i was wondering how hard it would be to put a th400 in. will i need a custom driveshaft, will i need to fabricate anything, and how much hp will aq th350 take. thanks
90 RS 305 tbi, 4 3/4" cowl Hood, Edelbrock TES headers, Flowmaster exhaust, Crane roller cam, comp roller rockers, vortec heads/intake, ported tbi, w/new injectors, MSD probillet Distributer/ coil, 1 inch tbi spacer, air foil, 14x4 k&n flat base air cleaner, Rebuilt 700r4 w/ B&M shift kit, B&M Megashifter, 3.23 posi, 2 12 RF's with mtx amp, top of line alpine cd player, soon to have 90-91 gfx, z-28 wing, new paintjob, rims, and all new lowered suspension.
Old Nov 23, 2001 | 12:20 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
A turbo 350 should take all a 383 can dish out. I have a turbo 400 in my camaro but I had to get a drive shaft built for it. The 200c crossmember will bolt up to it ( I had to elongate one hole) You will need an electronic down shift with a 400 that hooks up to the gas pedel. A turbo 350 is much easyer and economical to pop in there, 200c compoinets are a dime a dozen.
SSC
85 Camaro, 355/400 "drag car" current DD 13.1@ 101mph on its last season run.
Plans: Possibly add N20 for next season.
82 Firebird, 355/350, as soon as the powertrax gets installed. "dyno time"
Old Nov 23, 2001 | 12:25 PM
killer305's Avatar
so you think a 350 can take in access of 600hp, if so, im getting a 350, i know the swap is eiser
Old Nov 23, 2001 | 12:59 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
my friend put a TH400 in his 82 z28. I'm not sure what they did about the driveshaft. He has a whole garage full of them so he found a peice off one that fit his. He also made his own bracket for the torque arm.
Old Nov 23, 2001 | 03:15 PM
SoCo80p's Avatar
a BUILT th350 will handle it, not a stocker, a stock th400 should be allright tho, the th350 will be a bit of a easyer swap also/
Old Nov 23, 2001 | 03:55 PM
JucinGTA's Avatar
come on people look at the Sphon website on the top!!!!
heres the link to the cross member adapter
you can find the driveshafts and T/A on there too.
http://www.spohn.net/index.cfm?fusea...t&productid=20
Old Nov 23, 2001 | 05:36 PM
killer305's Avatar
how good is the b&m th350 tranny in the summit catalog # BMM-113001
Old Nov 23, 2001 | 09:54 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by killer305:
</font>
Thats a good one. My friend is running it behing a 500 hp BBC. It should hold up to your plans, but dont expect any tranny to last more than a few years with 600hp in front of it.
SSC
Old Nov 23, 2001 | 10:21 PM
killer305's Avatar
nice i love the price of that thing
bamaboy0323
Sep 3, 2015 06:07 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86White_T/A305
Aug 17, 2015 12:16 AM
cstrobel65
Aug 15, 2015 10:19 AM
