Axle Woes...
Old Nov 24, 2001 | 04:04 PM
Huckster's '84 TA's Avatar
Car: 1984 Pontiac Trans Am
Engine: 5.0L
Transmission: TH700-R4
Axle Woes...
My passenger side rear axle has about one inch of play going in and out; however it does not leak, but I'm worried my axle might fall out while I'm driving back and forth from Austin to go to school. I think it might be that axle bearing, but if anyone else has had this problem, what was it it? If it is the bearing, what is the procedure that I need to do to fix it?
Any help would be appreciated.
Thanx
1984 Trans Am Coupe
700-R4 Tranny
Mods:
K&N, Rebuilt carb, Rebuilt heads, 3" Mandrel Exhaust, Hooker Headers, Crane Cam, 1" Lowering Springs, Carion CD, Kicker Speakers, 2 MTX 4000, Pearl White Paint
"Live It To The Last"
Old Nov 24, 2001 | 04:58 PM
ede's Avatar
ede
if you have a inch of play, and i doubt you do, you need to STOP DRIVING IT and look at it, or have it looked at. i can't think of any way the axle can move that much without moving more and coming completely out. check it out to be sure and to be safe.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Nov 24, 2001 | 06:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
With the c-clip in place it shouldn't have any more than 1/4" at the most. If it has 1" then it sounds like the c-clip is missing and something else is preventing it from actually falling out.
Pull the rear cover and inspect.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Nov 24, 2001 | 06:15 PM
Engine: 5.0L
It may not be an inch, maybe about 1/2" to 3/8" only on the right axle. I have driven it like that for at least a year now. Do I need to replace the c-clip or is it something different? Maybe the axle needs replaced. I have not yet messed with my car behind the driveshaft, so what exactly do I need to do to fix this problem?
Thanx everyone.
Old Nov 25, 2001 | 09:36 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You have a C-clip to prevent the Axle from going outward, and there is a "cross pin" which holds the pinion gears to the carrier and keep the axles from going to far inward, which would cause the C-clips to fall out.
If you don't know about rear ends (which apparently you don't - not trying to offend) I would certainly have somebody familiar w/ them look at it.
I think its easy to "mis-judge" actual movement cause the tire makes it seem like more. I think if you were to measure play from the axle flange, it would be alot less than what you think it is, but I would have it checked out anyway, for peace of mind.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
6speedIROC
16
Mar 15, 2023 08:33 PM
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
