If you have a manual transmission come in!
Old Aug 21, 2009 | 06:59 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Where is your clutch safety switch and how is it connected? I bought one and I can't find a way to mount it. It's like a black boxy switch with a rather large rectangle button that gets pressed in.
Old Aug 21, 2009 | 07:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: If you have a manual transmission come in!
if its the factory switch, it mounts under the clutch pedal, there should be a tab on the pedal that hits the switch. I think. I can get a pic of mine tommorow.
Old Aug 22, 2009 | 10:52 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Old Aug 22, 2009 | 10:56 PM
9manastacio's Avatar
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
hey there. i have a question im doing a 350 swap, with the wc t-5 in my 88 bird. i know, i need the v8 bellhousoing, but what do i use for a flywheel, clutchdisc, and pressure plate, pilot bushing?
thanks
Old Aug 22, 2009 | 10:58 PM
keeslinger31's Avatar
Car: Camaro RS
Engine: obd2 350 lt1
thanks
Anyway, There should be a tab on the clutch pedal that it mounts to like 86ta said
Old Aug 22, 2009 | 10:59 PM
any body out there?! :?
Old Aug 23, 2009 | 03:23 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Here is a picture of my pedals. I must be blind because I don't see anything...
Old Aug 28, 2009 | 12:33 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Still trying to solve this mystery.
Old Aug 28, 2009 | 10:07 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
the black box that you have is for the 4th gen setup. 3rd gens use a white box(attached to the pedal frame) with a plastic rod that is connected to the pedal.
Old Aug 29, 2009 | 09:57 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
later model 3rd gens have the large black box switch.
earlier ones must have used the white box w/ sliding rod mentioned.
Those pedals are 82-83. Get some w/ the provisions for the black box style switch and the hydraulic master cylinder rod (tab welded to clutch pedal.)
Old Aug 29, 2009 | 11:30 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
I didn't have any trouble hooking the master cyl. rod up to these pedals....are there possibly minute differences that I may be bending the rod or messing something up?
Old Aug 30, 2009 | 04:17 PM
jmd's Avatar
jmd
You're right; I missed the hydraulic master cyl. tab; was looking at the hole in the pedal for early.
Here's a later set which obviously have a mounting area for the later black switch:
Old Aug 30, 2009 | 05:18 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
INCREDIBLY frustrating. I didn't even know there were different pedals out there. My swap is completed and I've been driving for a couple weeks now, forget the CSS, no way I'm taking those pedals out again. Maybe I'll try and fab something up down the road.
Old Aug 31, 2009 | 11:21 PM
s10irocspikes's Avatar
Car: 86 IROC
Engine: 350 Miniram
Just crimp the wires together and know your car. I never liked the CCS. At least make sure your e-brake works good and remember to put in neutral first.
Old Aug 31, 2009 | 11:46 PM
StringRust's Avatar
Car: '89 Camaro Rs/ '87 Z28
Engine: 305 c.i. TBI/ 305 c.i. 4bbl
Transmission: 700r4/T5
Axle/Gears: 3.73 posi/ 3.73 posi
Hotrodboba400
Dec 10, 2019 07:07 PM
angel2794
Sep 8, 2015 06:22 PM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
