will my shift linkage work ?
Old Aug 26, 2009 | 10:53 PM
nate perron's Avatar
Car: 83 berlinetta
Engine: 305 roller motor
Transmission: th350
Axle/Gears: 10 bolt 3.08
I am installing a th350 in my camaro that originaly had a 700r4
can I use the shifter and cable that came in it or do I need an aftermarket
Old Aug 27, 2009 | 10:41 AM
da.slyboy's Avatar
Car: 84 frankenstein Z28
Re: will my shift linkage work ?
Your shifter should be fine, but it might be a good idea to get an aftermarket cable that can be adjusted to make sure you can shift correctly. Do a search for th350 swaps and you should find all the info you need on it.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
