Strange 2-3 shift after shift kit install
Old Dec 6, 2001 | 10:08 PM
89rsvert's Avatar
Car: 1989 Camaro convertible
I had my 700r4 rebuilt by a buddy about 6 months ago. It worked flawless other than it shifted kind of low rpm. When I installed the tuned port motor, I had him install a b&m shift kit. The 1-2 shift is awesome but the 2-3 shift is weird. It shifts, but over rev's, then hits third and comes back down to normal rev's. He say's line pressure is low, but I just wondered if you had any ideas. thanks
89'Camaro Convertible,96'firebird wheels,79'Z28 hood scoop,soon to be a 350 tuned port injection engine, 3.27 posi disc brake rearend,36mm front sway bar, 24mm rear bar, all donated by a 89'Formula 350, Poly sway bar bushings and end links, Dark yellow green paint from Bonnevilles, tan www. mrmikes.com leather interior,Macewen white face gauges.
Dreaming of a RamJet 350,
Jet fan switch
180 degree thermostat
Flowmaster cat back system
2nd place is always the first loser!
Old Dec 7, 2001 | 11:41 PM
89rsvert's Avatar
anyone?
Jet fan switch
Old Dec 8, 2001 | 12:46 PM
Pro Built Automatics's Avatar
This is the major problem with the B&M kit. You wind up with a firm to very firm 1-2 shift, but the 2-3 shift in most cases gets worse, to say nothing about 4th gear. B&M does not address this problem, Trans-Go on the other hand with their Performance Shift kit will address the 2-3 & 3-4 shift problems by increasing the volume of oil to 3rd & 4th about three times, thereby decreasing 2-3 & 3-4 shift times and increasing capacity by a tremendous amount. There are other things the kit does also just to numerous to mention now. If I can be of help call me or e-mail me.
Hope This Helps!!!
Old Dec 8, 2001 | 07:28 PM
89rsvert's Avatar
Thank You. I looked at your site. I would be interested in the Transgo kits. What kit would be the best choice? Heavy duty/street/strip? I have a 350 Tuned port motor,stock, but with slp headers, 3.27 posi rearend and I have a nitrousworks kit for it. It should see no more the 100hp shot. The tranny worked great after the rebuild, but after the shift kit, it over revs on the 2-3 shift. I am assuming this is what the transgo kit is calling cutloose/spinup. I will let my buddy know, and see if he will change it to the transgo kit for me.If so, I will be in contact with you. Thank you again.
Jet fan switch
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
red90IROCls1
Aug 25, 2015 06:56 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
drathaar907
Aug 6, 2015 04:20 PM
