Pro built automatics shift kit ??
Old Dec 8, 2001 | 03:00 PM
redtail2426's Avatar
I have a 305 tpi motor that im planning on doing some mods too,but i also want to do some things to my 700r4.Right now it shifts at a good rpm but the shifts are very soft.It holds 1st 2nd and 3rd gear very well but lately seems like 4th is slipping.I just want to fix fourth gear from slipping and want some firmer shifts.Your website does not explain too much on the kits.I just want to know if i would want the heavy duty kit or the street/strip kit with the accumulator kit also. any help would be great thanks.
Old Dec 9, 2001 | 07:17 PM
Pro Built Automatics's Avatar
If you have a lot of miles and it is starting to slip a little in 4th, then the HD shift kit with Corvette servo & both boost valves should give you the best chance at keeping this unit alive for awhile. The HD kit already addresses the accumulation problem.
Old Dec 9, 2001 | 09:04 PM
It was just rebuilt like 5k miles ago so its a fresh tranny i think the fourth gear is slipping but im not positive if its just something else making it feel that way.If my fourth gear was not slipping but i just wanted to firm up the shifts,would u still recommend the HD kit.thanks
Old Dec 10, 2001 | 02:55 AM
YES!
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro11j
Sep 19, 2018 08:49 AM
LittleFranks
Sep 17, 2015 12:22 PM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
