Know when the slave is bad?
Old Sep 3, 2009 | 03:06 PM
Demon355's Avatar
I've bled the slave numerous times and it's still hard to get into gear sometimes. I put it in gear before I start the car now because it will grind everytime. Could my slave be bad? I don't know how to tell. It doesn't leak any fluid. To buy a new one is cheap enough but figured I'd throw a post up and see if theres anything I can check. Thanks!
Old Sep 3, 2009 | 08:14 PM
Pat Hall's Avatar
Re: Know when the slave is bad?
You might have the infamous problem of the throwout bearing being installed on the release fork incorrectly. It it is, that will cause it to not have enough travel to disengage the clutch disc completely. The guy on the boards here that just got his T5 swap finished ran into the same problem. If it's installed incorrectly, the spring steel tabs will be above the lips of the throwout bearing. When installed correctly, the spring steel tabs should rest inside, or just underneath the outer lips of the bearing (i.e. inside the race or groove). If you're sure this part is assembled correctly, you might have to resort to fabricating a longer pushrod for the slave cylinder to get the proper amount of fork travel.
Old Sep 3, 2009 | 09:26 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
You should have a peep hole on pass side of tranny its just a plug 1/2 inch I think. You can pull it and see if the slave is pushing the clutch fork also make sure you have correct fluid (atf) I put 85wt in mine and did not know it called for atf. I had the same problems.
Old Sep 8, 2009 | 05:48 PM
danandamy's Avatar
Car: 86 Camaro
If the slave is bad it will leak. If you can't get any pressure/movement, the master cylinder is bad.
Dan
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
gta892000
Sep 16, 2015 12:40 AM
armybyrd
Sep 15, 2015 06:06 PM
