Axle diameter issues!!!!! Please help
Car: 91 B4C 92 Z 93LT1
Engine: L98s & LT1s
Transmission: 700R4s all around
Axle/Gears: 3.23x2 & 3.73
My 92 G80, G92,GU5, J65.. posi disc 3.23 has a larger diameter axle at the splines.. anyone know why or where to get the right axle.. I've tried 28 spline axles out of 2 diff. 91 rears both of those were smaller in diameter, those were both drum rearends.. is the diameter different for a disc car?? Where is my best bet to get the right axle?? Thanks
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
Re: Axle diameter issues!!!!! Please help
do you have 9 or 10 bolts on the cover?your rear may not be original.
As far as I know all of the 26 vspline axles are the same size and all of the 28 spline 10 bolt axles are the same size. I've never seen any other splines on a 7.5 10 bolt. Check the rear end and be sure that you know which one you have. Could be a Dana 44 or 9 bolt.
Engine: L98s & LT1s
It's a 10 bolt... It's the orig rear.. end i'm the second owner my dad ordered the car new... I've never seen a different diameter till now.. The guts of this look different from my other posi units.. it doesn't have the springs in it. but it's not set up like the 9 bolts.. it's a 8mm bolt, slide the pin out, then c clips.
Engine: L98s & LT1s
I'll try to over the weekend..as much as i want to i haven't found a way to get paid for workin on my own sh*t.. so i had to put it back together i needed that bay.. I wish i would have thought to take some pics the first time i took it apart
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Well if it uses C-clips, it's not a 9 bolt or Dana 44. No 9 bolts were offered in production vehicles after 89 and the Dana 44 was an over the counter option. Your only other factory options are the 10 bolt with 28 spline, which is what the car should have come with or the smaller 26 spline if the diff was swapped for an older one but you say it's still original.
Hard to say exactly what you have without seeing pictures of it.
From the way you described taking it apart, it sounds like your carrier is just a standard, non-posi unit. And as stated above, all 90-92, 28 spline axles are the same diameter at the splines. I installed a 91, 10 bolt, 3.23 posi/disc rear in my 89. When I got it, I noticed one of the axles was slightly bent, so I went to the junkyard and grabbed an axle out of a 91 drum rear, and it fit/works perfectly. On that note, I'm at a loss to explain why it wouldn't be the same with the rear you've got.
Btw, whether it's posi or open carrier shouldn't make any difference in the axle size either. Maybe you've actually got one of the rare Dana 44 rears? Thread
TheTraut88
Sep 7, 2015 05:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
