Do I have to change the rearend?
Old Dec 13, 2001 | 10:46 PM
RSRagtop's Avatar
Ok I'm goin' to get a set of junkyard 3.42s to replace the 2.73s in my car right now. I am also goin' to get an SLP posi. I keep getting conflicting info. Some say all I need to do is change the gears 'cuz the posi is the 3-series carrier. Other sources say I must change the whole rear end since mine originally had 2-series gears. Who is right? You guys here said just gears and posi so I think your right.
Old Dec 13, 2001 | 11:12 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
OEM 3.42 gears are a series III. They will work with the SLP series III carrier. Basically, OEM gear ratios that are numerically higher then 3.08 are all series III. -Randy
Old Dec 13, 2001 | 11:47 PM
RSRagtop's Avatar
But do I have to change out the entire rear end drum to drum? Have 2.73s right now.
Old Dec 14, 2001 | 12:02 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You do not have to change the entire rear end. Housings and axles are the same for all ratios, within the specific rear ranges. THe SLP carrier will only fit the 89-up axles; and if your car is a 89 or even a 90, you really ought to pull an axle and make sure it's 28 splines before you buy the carrier, or be prepared to buy new axles (used ones are all but impossible to come up with, without buying a whole rear end).
ICON Motorsports
Old Dec 14, 2001 | 01:07 PM
RSRagtop's Avatar
Thank you for finally putting my mind at ease. I have a 91' so I'm sure I have 28-spline axles. I am goin' to the junkyard soon to pick up some gears! With my gears, posi and L35 S10 TQ my car should be much snappier when I get my engine/exhaust mods done. Thanks again guys!
Old Dec 14, 2001 | 02:06 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
MUCH snappier. I run the Zexel with 3.42 gears in my 91 Convertible and it is great.
billybob6110
Feb 11, 2016 10:41 AM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
