Automatic to Stick???
Old Sep 16, 2009 | 10:53 PM
Dany89's Avatar
I was just wondering how hard and expensive would it be to make my GTA Manual and which trans would be better T5 vs. T56??? it orginally has 5.7 w/700R tranny
Old Sep 17, 2009 | 06:46 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: Automatic to Stick???
I converted my car to a 5 speed from an automatic, and I didn't think that it was hard at all. You will need a manual transmission, flywheel, clutch, pressure plate, slave cylinder set-up, shifter, console plate, pedals, and the torque arm mount is different for a manual also. My swap costed me a little over $1000, not buying any cheap parts either. I think that a t56, tko 500 or 600 would be better to swap in because of how much more power than can handle compared to a t5.
Old Sep 17, 2009 | 07:39 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Like 85iroc-Z said it s not hard at all as long as you have all the parts. I did the the conversion to my camaro and i didnt have theTorque arm mount for the tranny and had to special order it from a GM dealership. It not cheap like $90 and that was with a discount.
Old Sep 18, 2009 | 12:08 AM
Dany89's Avatar
Thanx guys for the replys.
The only think taht gets me worried is the slave cylinder set-up. Would it be good to get this part form the original manual car or to buy it new(autozone, etc..)? And is any special tool needed to install the slave cylinder? I'm guessing i can get the torque arm mount form the original manual car right???
Old Sep 18, 2009 | 10:52 AM
Engine: 350TPI/ S50
Well i would get the entire Slave cylinder set up from the original car just to save alittle money. You could look up prices of a new setup compared to what you could get for it out of the original car. But thats just me. As for the Installing the slave cylinder to the bellhousing i used two long 3/8in bolts to pull it close and switch to shorter ones, one at a time. or just use your palm to push the rod in and quickly install it that way. And i would definatly get orginal torquer arm mount from the Manual car. The most important part is the steel clam shell you can always replace the bushing part with a urethatne one latter.
Old Sep 29, 2009 | 04:43 AM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
as for the swap itself, how hard is it exactly?
is it something that can be done in a weekend or is it a bigger project than that?
Old Sep 29, 2009 | 01:02 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
if you have everything on hand, are mechanically inclined and have a decent set of tools yes it can be done in a weekend easily.......
Old Sep 29, 2009 | 01:44 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Check out the sticky and FAQ. Plenty of info there. Only hiccup is mating the trans to a 2 piece rear block.
Old Oct 1, 2009 | 08:45 AM
Car: 85 Camaro IROC
Engine: 5.7 TPI
whats the hard part about a 2pc block?
Old Oct 1, 2009 | 09:17 AM
Car: 1984 Firebird
Axle/Gears: 4.10
an lt1 style t56 clutch requires a special flywheel if you have a 2 pc rear seal engine it is availible from centerforce and its about $400,
if you have a 86' up 1 pc seal engine, you can use a stock lt1 flywheel, i scored one at autozone for about $60+$100 core
Old Oct 26, 2009 | 12:25 AM
supremellama's Avatar
Car: Evo IX
Engine: 4 banger turbo
Transmission: 6 speeds of garbage
Axle/Gears: awd?
I'm thinking about doing this too and just buying a cheap ol' automatic camaro with low mileage and well taken care of body/interior. I just gotta choose the engine I want now that'll easily mate with a t56.
I'm new to the american muscle scene. I've always had a japanese import lol. Hope you do the auto swap successfully. I like to DIY since it puts more sentimental value on the car and you learn something from tearing/rebuilding.
Lbibb
May 5, 2016 12:00 AM
jrdturbo
Mar 31, 2016 02:58 PM
loud91rs
Oct 5, 2015 10:05 PM
bjpotter
Oct 4, 2015 07:48 PM
ndndndnd
Sep 28, 2015 08:00 AM
