T5 rebuild...
Car: '88 Iroc-Z z28 Camaro
Engine: Carb 355
Transmission: t5 5-speed
Axle/Gears: 4.11
T5 rebuild...
hey guys im jus spreadin out my options here and one of em is rebuild my t5 but i got 4:11's in my 10 bolt so i wanna go with a higher tranny gear and rebuild my whole tranny. what rebuild kits are out there that'll give me a higher tranny gear ratio? where can i find one? thanks for any help
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: T5 rebuild...
a 4.10:1 rear with the T5's 2.95:1 first is a good match. But if you're wanting a first gear ratio closer to 2.5:1, you can get it. G-Force used to sell them, they may still. The next most likely source would be Astro Performance. But be aware that it's cheaper and stronger to go to a T56 from a '95-'97 Z28/Formula/TransAm.
Engine: Carb 355
Axle/Gears: 4.11
Re: T5 rebuild...
ahhh ok, the 2.95 ratio is stock rite? acutally with all my parts with the clutch,bellhousing,slave,master etc etc, itd be easier to get the ls1 t56 and use the adaptor plate and extended pilot bushing that they make
Car: `86 SS / `87 SS
Re: T5 rebuild...
There should be parts to make it a 2.75 first gear.
Personally, I'd go with the 94-97 2.66 first gear LT1 T56 as I like the Valeo pull clutch.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: T5 rebuild...
IDKhis keeps resurfacing, but no T5 ever left the manufacturing plant with a 2.75:1 first gear. Maybe it was a typo, but it sure isn't real. 2.95:1 is as tall as they ever came.
TomP
May 20, 2002 03:26 PM
Ray87Z
May 8, 2002 09:31 AM
383, body, camaro, force, generation, gforce, kit, rebuild, rebuilding, rebuilt, speed, t5, trans, transmission, transmissions
