Rearend Swap
Old 09-22-2009, 10:46 PM
springer4's Avatar
Car: 1992 Heritage Edition Z28
Transmission: Stock
Axle/Gears: Stock
Rearend Swap
I'm doing an LS1 sway and will have a complete rearend from a 98 transam, will a 4gen rearend bolt into an 89 thirdgen if not, what needs tobe done?
Old 09-23-2009, 06:26 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Rearend Swap
I don't want to be rude, but that question has been asked more then couple hundred times. Do a SEARCH.......
Old 09-23-2009, 06:49 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Rearend Swap
Welcome to TGO. A search on site will often provide the info you're seeking. The following FAQ should provide the info you need:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
big gear head's Avatar
Re: Rearend Swap
I see that you are new here. Welcome. Here is some information that might help you. https://www.thirdgen.org/forums/tran...-10-bolts.html
The 4th gen rear end will bolt in, but it is a little wider.
Old 09-23-2009, 11:48 AM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
Re: Rearend Swap
yes it can be done, here is a pic of the lt1 style i have in my car with the stock wheels, just can't have the car full of people on bumpy roads....
Nervous2
LSX and LTX Parts
03-10-2016 09:49 PM
theshackle
08-22-2015 06:52 PM
Hello, Michael
08-20-2015 03:19 PM
355sbcTPI
08-19-2015 04:38 PM
86White_T/A305
08-17-2015 12:16 AM
Quick Reply: Rearend Swap
