axle flange to axle flange
Old Oct 6, 2009 | 08:49 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
I did a search.61.5 inches, is the axle flange the part that the wheel studs are pressed into, or does that refer to the 4 bolt flange that the brake backing plate mounts to?
Thanks-
Eric
Old Oct 6, 2009 | 10:56 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: axle flange to axle flange
The part the wheel studs go through is the axle flange. That will be the outside limit (except for a drum or rotor) that your wheel will attach to.
The 3 or 4 bolt flange that holds the backing plate/caliper mount is the housing end.
Old Oct 6, 2009 | 11:02 PM
ericjon262's Avatar
Thank you very much!
What do our factory rears measure to the housing ends?
Thanks-
Eric
no green
Jan 9, 2016 09:22 PM
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
