Chirping noise???
Old Nov 7, 2009 | 08:52 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Chirping noise???
I put a T5 in my camaro conversion. I can hear a chirping noise unless I step on the clutch a bit and then it goes away it does it when i am driving. I am wondering is that the pilot bushing or the throw out bearing? Being new? Its faint noise and chirps a bit then when i barely hold on the clutch like just put my foot on it. It goes away? any suggestions?
Old Nov 7, 2009 | 09:05 PM
toomany's Avatar
Re: Chirping noise???
My guess would be throwout bearing, if it goes away when you step on the clutch. The or the fork may be vibrating and you are hearing that. Pilot bushing is on constant contact with the input shaft, sometimes spinning faster or the same speed, but always in contact.
Old Nov 7, 2009 | 09:12 PM
berlin305's Avatar
Nothing bad then right? I mean its all new parts clutch kit.
Old Nov 7, 2009 | 09:19 PM
berlin305's Avatar
The only thing thats used it the fork. And that seems obvious if you apply little pressure not to disengage just to where the cylinder holds the fork a bit probably just chirping on the throw out bearing by vibration.
Old Nov 7, 2009 | 10:13 PM
berlin305's Avatar
any takers on this thing i have? I don't see it much of a problem it drives and clutch is fully functional. Even did a test to make sure the clutch engages by putting it in 3rd gear and letting off to see the car stalls. and it does rather quickly.
Old Nov 7, 2009 | 10:46 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
most likely your t.o. bearing...........
Old Nov 7, 2009 | 10:55 PM
berlin305's Avatar
being brand new doing that? never had a throw out bearing do that before.
Old Nov 7, 2009 | 11:02 PM
i have had it happen to my other camaro 5 yrs ago.....twice
Old Nov 7, 2009 | 11:04 PM
berlin305's Avatar
Anything bad involved in it chirping?
Old Nov 8, 2009 | 03:53 PM
drove it around for awhile then the throw out bearing disintegrated. luckily i wasnt too far from home and i was able to drive it home...........
Old Nov 8, 2009 | 05:38 PM
berlin305's Avatar
Hmm. Well I will see if it will go away if not. I guess i will be pulling it out again. I just don't understand why would a new t.o would do that.
Old Aug 30, 2013 | 01:50 AM
1986 305 RS's Avatar
Car: 1986 Sport Coupe
Engine: 305 V-8 670 cfm Holley st avenger
Axle/Gears: 13-42
2009 darn im too late I was gonna scream pull it out and put it back together. What I thought was my clutch making noise it ended up being
my throw out bearing and due to lack of money and able to line up my mechanic it exploded cracked the front and back case ultimately destroying the whole thing. Who ever reads this if you have tranny noise no mattet how minor get it addressed asap especially if it's a t5
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
