converter bolts not lining up?HELP ME!
Car: Camaro sc
Engine: 350 cid.
Just got my rebuilt one piece rear seal 350 into the car to discover that the torque converter doesn't line up with any of the 6 holes on the flex plate?!?After flipping out for a minute,i had a look at my old flex plate on the old 2 piece r.m.s. 350, and can see two sets of holes on that flex plate.3 are closer to the edge than the other 3 are.Apparently,the newer flex plate doesn't have that.These are both 168 tooth flywheels by the way.Anybody ever run into this problem before?I'm not a very happy boy right now,please help.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: converter bolts not lining up?HELP ME!
The older dual set of bolt holes is for OEM TH350 or TH400 torque converters. The majority of the aftermarket converters use the TH350 pattern but that doesn't mean you can't put a TH350 converter onto a TH400 or even a powerglide with a turbo spline input shaft.
Is your new flexplate designed specifically for a TH350 or a TH400? Most will have a dual bolt pattern or a TH350 pattern.
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Sound like you need 1 of 3 things
{1} Dual pattern flex plate (will eliminate this in future swaps-use with any torque converter)
{2} Dual pattern torque convereter ( see above & somewhat pricey)
{3} Correct flex plate with correct bolt pattern
That's all I can think of.
[edit]
Thanks for the info Stephen!! I had NO idea there was that issue!!!
HAPPY THANKSGIVING
[edit]
HAPPY THANKSGIVING
Last edited by t-top havoc; Nov 25, 2009 at 08:20 PM. Reason: Better ans from Stephen 87 IROC
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
don"t diesel motor flywheels have six bolt flywheel/torque converter patterns
Car: 87 IROC L98
yes they do and all the bolt holes are the same distance but "flywheel" and "torque converter" don't go together. It's called a flexplate.
Although I've never tried it, I doubt a diesel flexplate will even attach to a 350's crank.
Car: Camaro sc
Engine: 350 cid.
I'm ok now.I spent a couple hours unhooking the motor and have it hanging from a chain as i type this.Went down to my local NAPA and lo and behold,they have the proper flexplate for a 1 piece with dual bolt pattern.I don't know how i ended up with this orphan one,it must go to a truck or something that doesn't use the 700R4 trans.I do know that i won't do another motor swap without checking first.Thanks for putting in your 2 cents guys'
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
