ford 9 inch
Car: 84 trans am
ford 9 inch
i am looking at getting a ford 9 in ch for my formula, does any one here have a 9 inch? where would i be able to find one that has all the factory brakets that bolt in to third gens?
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Re: ford 9 inch
Currie, Moser, and any number of other companies make a 9" housing with factory brackets for Camaro's and Firebird's.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: ford 9 inch
You can support one of the TGO vendors such as www.spohn.org who will also carry one of the aftermarket bolt in diffs.
Re: ford 9 inch
Are you looking for a housing and axle package or a complete rear end? You can get the housing and axle package and use a junk yard center, or get a complete rear end. The center chunk is the most expensive part.
Car: '82 Z28
Re: ford 9 inch
Mine is all Currie stuff minus the center section which I got local. Everything bolted up good, just a little grinding on their torque arm bracket to fix a spot where it was hitting the center section. Not sure if they've changed it by now.
Car: 87 IROC L98
Re: ford 9 inch
The above picture should include the axles as part of the diff package. Order it with 31 spline axles then find a junkyard center section with a 31 spline posi and hopefully a gear ratio that you can live with and pop it in.
Car: 98 Camaro Z28
Engine: 346 LS1
Axle/Gears: 3:43
Re: ford 9 inch
k,..... so i am gettin a ford 9 inch from a frnd for free. I am wanting to go with gears like 3:73's or 4:10 now i DO NOT no much bout rears, so what should i go with?? i got a rearend with all the brackets i can cut off and weld to the 9inch but other then that i am unsure i am going with a ls1/t56 running bout 400-450 horses. something to handle the abuse
LT1Formula
Oct 8, 2015 08:34 PM
