Clutch master cylinder location for T5 swap?
Engine: None
Transmission: None
This hole is already in my firewall and I just want to make sure that this is where the master cylinder would go. Thanks all.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Clutch master cylinder location for T5 swap?
I'm pretty sure if you bolt the brake/clutch pedals into the car, the support brackets will swing down to the firewall and show you exactly where you want to put the mounting bolt holes. Then you can make a template and drill the holes. It doesn't seem to be all that big a deal how exact the holes are located.
I wonder if the brackets show where on the firewall the holes need to be then what's the use of the template? You could put a mark through the bracket holes and then drill?
bigjay89gta
Oct 15, 2015 08:04 AM
Denricci22
Sep 18, 2015 09:02 AM
