Positive traction
Old Feb 5, 2010 | 06:54 PM
blaznhot's Avatar
Car: 1992 Firebird
Engine: Stock 305 TBI
Transmission: auto / stock
Axle/Gears: Stock
Positive traction
Are the '92 Firebirds with the 305 TBI engine positive traction cars? Just wondering. Thanks for any info!
Old Feb 5, 2010 | 07:06 PM
Drew's Avatar
Re: Positive traction
Probably not. Check the SPID in the trunk for RPO code G80. Or jack up the back of the car and see if both wheels turn the same direction.
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
probably not, but there is no way to know what rear ended up in the car after 18+ years.
jack up the rear of the car and rotate a tire, if the other spins in the opposite direction, its an open rear. both the same way, a limited slip
damn you drew, beat me by seconds!!!
Old Feb 5, 2010 | 07:29 PM
Drew's Avatar
You've gotta be quick with your click.
Old Feb 5, 2010 | 08:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
As I understand it, if both wheels rotate in the same direction, you have limited slip. If wheels rotate in opposite directions, you have either an open diff or a worn out limited slip. Best to drop the cover and take a peek. More info in the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Feb 6, 2010 | 06:17 PM
blaznhot's Avatar
Car: 1992 Firebird
Axle/Gears: Stock
It's an all original car with 107k miles. I was just wondering how they came from the factory rear end wise. I'll jack it up some day, no biggy.
Old Feb 7, 2010 | 12:45 AM
Drew's Avatar
Some engine packages required G80, but the L03 packages didn't. In general, most of the time G80 was an at cost option that could be added to anything. Also it's been long enough that anything could under there.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
gta892000
Aug 11, 2019 11:16 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
dbrochard
Sep 7, 2015 09:41 AM
