What keeps the clutch fork in blase with the bearing?
Old Feb 6, 2010 | 06:26 PM
89FRMLA350's Avatar
Engine: None
Transmission: None
So I am at the point of my install that I have another question. The bellhousing and all have been put on. On the clutch fork where the pivot ball sits there are two small hooks. Do those go underneath the pivot ball or what? What holds the fork in place while I slide the transmission in? I'm confused.
Old Feb 6, 2010 | 07:30 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
Re: What keeps the clutch fork in blase with the bearing?
http://www.autozone.com/autozone/cat...0&parentId=179
Old Feb 6, 2010 | 07:59 PM
89FRMLA350's Avatar
Engine: None
Transmission: None
I've seen that before but it doesn't answer my question. I see from the thread https://www.thirdgen.org/forums/tran...y-t5-swap.html that he hasn't yet installed the clutch slave cylinder and somehow the fork is sitting in there all nice. I thought it would have been the pressure from the cylinder keeping pressure on it but that isn't the case. I'm still stumped.
Old Feb 6, 2010 | 08:31 PM
Engine: 383 Stroker
Transmission: t-56
Im really not sure myself. Could you link me to the picture of it?
Old Feb 6, 2010 | 09:20 PM
89FRMLA350's Avatar
Engine: None
Transmission: None
Old Feb 6, 2010 | 09:37 PM
Engine: 383 Stroker
Transmission: t-56
does yours pivot on a ball?
Old Feb 6, 2010 | 10:17 PM
ls six's Avatar
There should be a clip on the fork, when it's on correctly it simply snaps in place over the ball stud.
Old Feb 7, 2010 | 12:41 AM
Drew's Avatar
Originally Posted by 89FRMLA350
See the rubber dust boot around the clutch fork in the picture that you appear to be missing? That boot combined with the fingers on the back of the clutch fork slipped over the pivot pin are keeping his fork sort of centered.
Old Feb 7, 2010 | 07:03 AM
89FRMLA350's Avatar
Engine: None
Transmission: None
Well the guy I bought this from never had the boot either. So the two prongs on the back of the clutch fork stay on top of the pivot pin and then I should be good? I thought they slide under?
Old Feb 7, 2010 | 07:33 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
they DO slide under the ball on the pivot stud . i have done a couple of them . the most recent 3 weeks ago . you are correct , good luck .
Old Feb 7, 2010 | 07:43 AM
89FRMLA350's Avatar
Engine: None
Transmission: None
Thank you
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
