Hits Neutral @ 125mph????
Old Feb 8, 2010 | 01:58 AM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
Specs:
350 - Bored .060 over (360)
Mild Cam
Forged Internals
Head Work
TCI Racing 700r4
Manual\Automatic Valve Body
Torque Converter Specs are evading my mind right now
3:73's
Problem:
During a top speed run on a private course (cough, cough) I came into a lil issue... At 125mph (4k'ish rpm), the nose sank and the tranny noticably went into neutral - pegging the R's... I figured the tranny blew, considering that and there was no engine braking while the rpm's receded... Around 90mph though, 4th gear came back to life and the normal decelerating growl screamed in my ears again... I reset and tried it once more with the same results... WOT shifts are firm 1st-4th and still drives strong\normal as it sits; it's only seeing issues beyond 125mph...
I'm clueless to what the issue could be, this car has seen 140+ with no prior problem... Any thoughts guys??
Old Feb 8, 2010 | 12:49 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Re: Hits Neutral @ 125mph????
Originally Posted by C-Titan
Specs:
Has this problem occured since the tci valvebody installation??
Old Feb 8, 2010 | 03:00 PM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Axle/Gears: 3:73
The valvebody was pre-installed by TCI as part of a package deal I purchased thru them... This set-up has a little over 30k of heavily spirited driving, with no prior issue...
Side Note: The first run was shifted, the second was in full auto - both resulting in the same problem...
Old Feb 9, 2010 | 03:16 PM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Axle/Gears: 3:73
Old Feb 9, 2010 | 03:55 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Do you have a lockup converter? Do you notice any lockup action in normal street driving? IIRC, the TPI ECM code has a force lock up around 125mph... You're not hitting a Speed limiter (ECM or MSD) are you?
Old Feb 9, 2010 | 03:58 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
maybe (just maybe) its a general? limits your speed? i dont really kno :P just spit balliin
Old Feb 9, 2010 | 04:09 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Originally Posted by itsMikey
general
U mean governor?
Old Feb 11, 2010 | 06:35 AM
Cameron@TCI's Avatar
Titan.. Was the converter locked up at this point? There is a couple of things that could cause this to happen. You have been driving it around fairly normal since? Has it experienced any slipping? Any converter shudder when it locks up?
Cameron
TCI Auto
Old Feb 11, 2010 | 08:12 AM
Check the fluid level. This could be as simple low fluid, and the transmission is beginning to starve at that MPH.
Cameron
TCI Auto
Old Feb 11, 2010 | 04:06 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
Originally Posted by chas0218
U mean governor?
ive heard it by both names...but yeah
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
apie2546
Oct 16, 2016 02:24 PM
RS Reaper
Sep 27, 2015 07:04 PM
Twinn Engines
Sep 25, 2015 06:27 AM
