Help me out please?? Bad wheel bearings?
Old Feb 13, 2010 | 09:47 PM
hung4wheeler's Avatar
Car: 87z28
Engine: 70 LT1
Transmission: 350 TURBO BUILT BY B&M
Axle/Gears: 12 BOLT POSI
Is it possible for both my rear wheel bearings to be bad? when i jacked my car up and moved my tire side to side it moves alot . on both sides. i notice it when iam going slow around corners to... this rear end is not a factory unit it is a 12 bolt posi unit with 411 gears . that was swapped in with my 350.
it shifts fine. no problems with that . its just the movemant and it makes a clunking noise when i move the tires in and out on both tires????????? I figured i would ask here first. thanx let me know please .
xxx3man`
Sep 23, 2015 10:37 PM
dyeager535
Aug 28, 2015 08:10 AM
Dialed_In
Aug 20, 2015 01:45 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
